Curtiss SB2C Helldiver (Dive bomber)
FGM General
The Curtiss SB2C Helldiver was a carrier-based dive bomber aircraft produced for the United States Navy during World War II. It replaced the Douglas SBD Dauntless in US Navy service. Despite its size, the SB2C was much faster than the SBD it replaced.-
Have difficult handling characteristics. Neither pilots nor aircraft carrier skippers seemed to like it.-
The Curtiss Helldiver, despite a reputation for being difficult to handle at low speeds, was responsible for the destruction of more Japanese targets than any other aircraft. The Curtiss SB2C single-engine dive-bomber joined the fleet late in 1943, joining the Douglas Dauntless as the primary attack/bombing planes for the US Navy. The two-man Helldiver had a top speed of 295 mph and good range, making it an essential tool in the far reaches of the Pacific war.-
With underwing and bomb attachments, the Helldiver could carry 1,000 pounds of bombs or an internal torpedo; later improvements included an up-rated Wright Cyclone engine and rocket hard-points. It carried two fixed forward 20mm cannon and machine guns in the rear cockpit.-
Only 26 of the 7,000 Helldivers built found their way to the other services; the plane was so valuable in the Pacific theater that the Navy absorbed nearly every plane. Postwar, the Helldiver found further use with the French, Italian, Greek and Portuguese Navies and the Royal Thai Air Force.-
Specifications (SB2C-4 model):
Engine: One 1,900-hp Wright R-2600-20 Cyclone 14 radial piston engine
Weight: Empty 10,547 lbs., Max Takeoff 16,616 lbs.
Wing Span: 49ft. 9in.
Length: 36ft. 8in.
Height: 13ft. 2in.
Performance:
Maximum Speed: 295 mph
Cruising Speed: 158 mph
Ceiling: 29,100 ft.
Range: 1,165 miles
Armament:
Two 20-mm wing-mounted cannon and two 7.62-mm (0.3-inch) machine guns in rear cockpit;
Up to 2,000 pounds of bombs on underwing racks and in fuselage bay.
wiki
warbirdalley
The Dauntless could carry up to a 725-kilogram (1,600-pound) bomb on a swinging release cradle under the fuselage, and also had a pylon for a single 45-kilogram (100-pound) bomb or other relatively small store under each wing. The release cradle allowed the bomb to clear the propeller during a dive attack. The cradle was not used in level attack, the bomb being dropped directly in that case.
Ha! Ya think? :D
You know, my brother is a bit of a math dweeb and he thought about it a moment and said he thinks physics dictates that the bomb cannot drop faster than the plane is going in a dive. In fact once the bomb is released it should start going slower than the plane. :unsure:
Douglas SBD Dauntless didn't have the cradle.
Maybe they kept blowing up their props so they added the cradle.;)
Named after the Bennington Vermont and the battle that took place there.
"The battle was part of the Saratoga Campaign and a pivotal victory for the Americans. The British suffered heavy losses and failed to gather supplies for their push on Albany. The shortage of supplies contributed to General Burgoyne's surrender at Saratoga in October 1777."
I always wonder what it is like to be a pilot with a perfectly fine plying plane and then gettiing an "upgrade" that flies like a turd. It guess that's life in the military.
Photo Credit: With both canopies pulled back, a SB2C-3 Helldiver makes a pass over its carrier, USS Hornet (CV-12) in the South China Sea, January 1945. SB2Cs accounted for more enemy ship tonnage sunk during the war than any other aircraft.
