I have found a strange thing with this game, at first I thought that I had not understood the LOS tool properly but now I have tested it and something is really strange. I did a experiment where I advanced NE --> SW towards the road crossing Rue de Poteau/Rue de la Croix at the Aachen map (starting the advance 400 meters from the road crossing). I placed three squads of german squads in a building which has a little bric wall in front of it facing SW --> NE from the road crossing Rue de Poteau/Rue de la Croix (the big road crossing 100 - 150 meters south of Min VP Nikolas Kirche). The bric wall covers the first level at the building but not the three other levels above. First I ran up with a tank and a platoon leader on top of it. The tank could not engange the three german squads (the manual command "Target" does not work because the LOS-tool says there is no LOS), but the three german squads fired upon the platoon leader on top of the tank. I hade to close the distance with at least 50-100 meters and then suddenly the tank could fire at the levels above the bric wall, but when I want to use the command "Target" after supressing the germans the LOS-tool ones again says "No line of sights". I could give the command "Target" with my infantry squads which i brought up to test if the same problem affects infantry, but they had no problem to manually Target the hig. This has to be a bug or something?
The LOS tool tells me that there is no line of sight towards the levels above the bric wall, but the real LOS when I watch from the tank tells me othervise, even more strange is that infantry who are lower down then the turret can engange with help of the command "Target" with no problem. I have experienced this before and not only in urban combat, the difference between the games "LOS" and the real LOS (with tanks) when I have played single player, it is annoying when u manouvers to a position with a tank and then it can not engage. Infantry seems not to have this problem. I have not any recording tool, but try it out your self and you'll notice this very strange thing. A 1.80 cm bric wall does NOT cover a window that is 4 meters up and it is really strange that there is a difference between tanks and infantry when they stand at the same place.
Any one else who has experienced this?
Is there any place where one can report this odd things so that the game makers can fix this?
