running CM higher than 1920 x 1080
DoubleD
FGM 2nd Lieutenant
London, UK
Website
www.youtube.com
I've upgraded my computer and can now run at 2560 x 1440 screen resolution. When I run CM in this resolution it looks rubbish because it's defaulted to much lower resolution. Setting 1920 x 1080 isn't an option in the settings. Does anyone know if it will run at 2560 x 1440 and if not, any ideas how I force it to run at 1920 x 1080 without having to change my settings every time.
User -> Documents -> Battlefront -> Combat Mission -> "Game"
Look for the text file "Display Size." Open the document, first two numbers are width x height, third number is the refresh rate. If the file says "0 0 0" then it will default to your system settings. So in your case it would be "1920 1080 144" (or whatver your refresh rate is).
Save and copy this text file into the folders for the other games.
