Saint-Chamond (Tank)
FGM General
Originally the tank produced by Saint Chamond was meant to be identical to the Schneider CA. Early 1916, the proposed definitive prototype of this latter tank was prepared in an army workshop. The type used tracks from the American-made Holt caterpillar tractors that were already employed in France for towing heavy artillery. Private Pierre Lescure designed the fighting compartment. Lieutenant Fouché lengthened the suspension to improve trenchcrossing abilities. In this form the prototype of the Schneider was called the Tracteur A - not for security reasons, but because nobody knew exactly how to call such vehicles; the word char was not yet applied to tanks. However Eugène Brillié, the chief designer working for the Schneider Company, rejected this prototype. He had invented a tail giving a shorter chassis providing the same trench crossing abilities for a lesser weight.
While Brillié began to design a second prototype (based on his earlier work on the Schneider CA-1), Schneider's main competitor, the arms manufacturer "Forges et Acieries de la Marine et Homecourt à Saint Chamond", was given a second order for 400 tanks. First they intended to build the same tank as Schneider. However Brillié refused to share his patented invention for free and Saint Chamond refused to pay. So the latter company, not even having been given the blueprints of the new Schneider prototype, had to base its design on the original Tracteur A. Because of this the designs of the two companies began to diverge already, as the Tracteur A was longer.
One of Saint Chamond's technical directors was colonel Émile Rimailho, an artillery officer who had become disgruntled over the meagre benefits he had received for helping design the famous Canon de 75 modele 1897 field gun as well as the Mle 1904 155 mm howitzer. After Emile Rimailho had joined the firm at Saint Chamond he designed a 75 mm field gun, somewhat similar to the Mle 1897 75 mm gun he had co-designed with Ste Claire Deville. It was the Saint Chamond L12 Canon à Tir Rapide ('Rapid Fire Cannon'), on which he received a percentage for every gun being sold. This was too good an opportunity to let pass and Rimailho induced the Ministry of War to change the specification of their order so that the new St Chamond tank would be able to mount his gun, even though the army had never asked for such a capacity. To achieve this, a longer hull than on the Schneider tank was needed. The first prototype, now quite distinct from the Schneider, was ready in September 1916.
When Colonel Jean-Baptiste Eugène Estienne, who had taken the initiative to create the French tank arm, learned of the order for 400 tanks more, he was at first very gratified. When it later became clear however they would be of a different tank type, he was shocked and wrote: "I am painfully surprised that an order has been launched of this importance without asking the opinion of the only officer who, at the time, had undertaken a profound study of the technical and military aspects involved and who had brought the supreme commander to the decision to take this path [towards a tank arm]."
St Chamond tanks being built in the factory. It was recommended that additional 8.5 mm plates should be added to the side plates (which were a basic 8.5 mm.) to give full protection against the German "K" bullet, although this modification was not carried out in full.
As a result of Rimailho's manipulations, the new tank had become a rather cumbersome vehicle. It had no turret, but a large overhanging front compartment housing the long 75 mm gun, protruding from the nose. Within the forward fighting compartment was the driver, who was also the vehicle commander, on the left. On the right a machine gunner operated the front machine gun. This gunner was also responsible for traversing the main gun and the breech operation of the same which he could only do by getting out of his seat and using his left hand. A loader (referred to in some sources as the gunner) adjusted the gun elevation, observing the target through a large hatch in the front of the tank, which left him vulnerable and many were killed by enemy fire.
Gunner positions in the St-Chamond. You can see just how poorly the side machine gun positions were thought out. The gunner has to crouch down in an awkward position. His shin is inches from a sharp corner of the arch over the tracks. The heat and noise from the engine, located a foot or two away, must have been unbearable.
A second fighting compartment at the back held one machine gunner next to the secondary driver position, from where the tank could be driven backwards by the mechanic in an emergency. Between these two compartments was the 90 engine over the tracks, partly protruding through the roof. Narrow passageways either side of the engine connected the compartments, each also containing a machine gun position.
The very first St Chamonds were modified as recovery vehicles able to tow the lighter Schneider tanks. The first action as a fighting tank was 5 May 1917, mostly getting stuck in various trenches. Twelve units in total were formed with the St Chamond: Artillerie Spéciale No's 31-42.
Production petered out in March 1918, when at least 377 had been manufactured. After the war 54 were rebuilt as munition carriers; the remainder scrapped.
Specifications
Weight 23 tonnes
Length 8.9 m
Width 2.7 m
Height 2.4 m
Crew 8 (commander-driver, gunner-loader, assistant gunner, four machine gunners, mechanic)
Armor 11–19 mm
Main armament
75 mm gun
Secondary armament
four 8 mm Hotchkiss M1914 machine guns
Engine 4-cylinder Panhard-Levassor (petrol)
90 hp (70 kW), Crochat-Colardeau electric transmission
Power/weight 4 hp/tonne
Suspension coil spring
Speed 12 km/h
landships.activeboard.com
dieselpunks.org
forum.valka.cz
makarih-203.livejournal.com
That was only since their very first tanks at all were bought french and british tanks. That stuck for the further development of their tanks. ;)
Greetings :)
