Help with converting scenarios to QB.
stardekk
FGM Sergeant
Israel
6+ pw
5-8 games.
I want to convert the map "To Verdenne & Victory" in CMFB into a QB map, I already marked the objectives and starting zones for each side, what should I do next ? I puted it in the QB maps folder with 284p ( I want it to be probe) I cant find it in the QB section, what should I do next ?
BornGinger
FGM Sergeant
Wales, UK
1-2 pw
I'm pretty sure that you also need to do a plan for each side. If you want to play it as H2H only you can do a few quick moves for four or five groups for each side which don't mean much just to fool the engine.
You also have to make sure that the size in the Mission section in the editor show the size of the map you are searching for.
If the map is "large" in the editor's mission section you won't find it if you search for huge.
Check a quick battle map in the editor to find whether you have missed something.
