How to Load Maps onto Scenario Depot?
G
Gazmaps
Hello,
Ive being creating / modifying some stock maps for CMSF2 - I ve taken the stock UK Armoured Assault Map and "Urbanised" it....
Also intensified the vegetation and terrain on the central east flank as well.
2 Maps - one is a dedicated Uncons vs Conventional QB Map and the other is a Conventionals vs Conventionals Assault Map.
Ive tried uploading but my Few Good Men Login does not seem to let me get to the uploads page / is not recognised...
Does an authorized author need to do this???
Here's the details for the the UNCONs vs Conventionals Map;
Acknowledgements:
Map is modified from Stock British Forces Map from Battlefront - UK Armoured Assault SF
Dedicated UNCONS vs CON QB Map.
Map Settings'
Moderate Civilian Density
50% Intel to Redfor
Map amd objectives is set up for;
UNCONS - REDFOR
CONVENTIONALs - BLUEFOR
Max Points 200pts - Possible for either player.
Map Setup with 5 Objectives for both sides to contest (Total 100pts);
The Villa 20pts
The Grand Mosque 30pts
Insurgent HQ 15pts
Weapons Cache 15pts
Local Mosque 20pts
Following Conditions for Conventionals;
Inflict > 75% Casualties on Enemy 50pts
Suffer < 50% Friendly Casualties 50pts
Following Conditions for UnConventionals;
Inflict > 50% Casualties on Enemy
Suffer < 75% Friendly Casualties 50pts
Conventional Forces will also be penalsied for every Building they Destroy in that a point binus will be given to the UNCONs.
Buildings < 4 Actions Squares in size destroyed will cost the Con Player -10pts
Buildings = 4 Actions Squares in size destroyed will cost the Con Player -20pts
as an example - The Grand Mosque will cost the Conventional Player -190pts if fully destroyed.
In theory if all buildings on the map are destroyed - the UNCONs player can recive in total an addiitonal 6130 points...
Cheers
Gary
