P
PoorOldSpike
BOCAGE, LOW BOCAGE and HEDGEROWS (manual p.34)
This screenshot includes all 3 types.
Bocage and low bocage both block standard vehicle and infantry movement, and they both block LOS unless you've got your nose in it, but low boc is easier to see over, especially if you're on higher ground or on the top floor of a building.
Hedgerows don't block movement.
Test 'A'- I gave the tank a move order straight through the low boc but it ignored me and went round the left end of it, crashing through a hedgerow in the process.
Test 'B'- I ordered the tank to crash straight through the hedgerows and it went straight through, creating gaps as it went. (the gaps weren't there when it started)
(Incidentally the piles of rubble at lower left are the remains of a wall demolished by Sherman fire)
STANDARD UNITS CAN'T GO THROUGH BOCAGE: (specialized units can, and i'll test them in due course)
Note: the manual says there's Bocage and there's ordinary smaller hedges, not to confuse the two. I'll test out ordinary hedges later
I give our boy a move order straight through the Bocage-
But he completely ignores me and goes through a gap-
Infantry ignored me too, and went through a small gap-
