No aim point reverse slop
V
Vox
Any one have any good tips and/or tricks for No aim point reverse slop. its the most annoying thing when you can see the area but cant fire on it:(
A Canadian Cat
FGM Lieutenant
Ontario, Canada
3-5 pw
5-8 games.
Email
ian.leslie@lesliesoftware.com
The point of that is that the shooter cannot see the ground that location. The message further indicates that if an enemy were to position them selves in that location they would be visible.
So are you trying to put some area fire down on that location? If so then I suggest targeting the nearest location you can and let the spill over effects work their magic.
If you are trying to position a vehicle in a good location to see the enemy approach then you might have found a good spot :)
domfluff
FGM Private
UK
6+ pw
That or using indirect fire - within 30m you can throw grenades over slopes that you can't target directly, and mortars can fire just over a slope they can't see.
